De motor van Sjaak
Plaats hier een foto-link naar je GR (voor uitleg zie "Info")
User avatar
sjaak55
De motor van Sjaak
Postby sjaak55 » 10 Apr 2009, 10:39
sjaak
User avatar
vtwin
Postby vtwin » 09 May 2009, 17:23
Hi, great looking bike. I was wondering if the taillamp and the turn signal location is stock. My turn signals are mounted on the grab bar, not the taillamp. But I would like to switch it to the taillamp as that would allow me to use saddlebags and not interfere with the turn signals. Thanks
User avatar
sjaak55
turn signal
Postby sjaak55 » 09 May 2009, 20:32
Hi vtwin
The taillamp and the turn signal location is stock
for my model gr650x.
The Tempter with cast wheels and airpressure front forks
has turn signals mounted on the grab bar.
In this link you can find out wich parts between the gr650x and tempter
will be interchangeble http://www.mrcycles.com/fiche_section_d ... &fveh=2125
succes
Sjaak
sjaak
User avatar
sjaak55
turn signal
Postby sjaak55 » 09 May 2009, 20:53
I found these pictures on
The red circle indicates the hole for the turn light.
sjaak
User avatar
vtwin
Postby vtwin » 10 May 2009, 16:46
Thanks Sjaak for the info. I will try to find a taillamp assembly like yours so I can mount my turn signals further back. Thus allowing me to mount touring bags. Will post a picture when I can.
roland
User avatar
vtwin
Postby vtwin » 21 Jan 2010, 04:02
Hi Sjaak, I was able to source a taillamp such as yours. unfortunately during shipping, the tail lens became damaged. Do you know where I can for a good used one? Seems these types came only on the later models and being that the bike lasted only one year here, that lens is impossible to find. Thanks.
User avatar
sjaak55
Postby sjaak55 » 21 Jan 2010, 09:05
Hi vtwin
In this link you can find and order a lens.
succes
Sjaak
sjaak
User avatar
vtwin
Postby vtwin » 22 Jan 2010, 03:37
Thanks, will let you know how it turns out.
Return to “GR Foto-Album”
Who is online
Users browsing this forum: No registered users and 1 guest
